Need some help with some prices for 4' x 8' signs
MTechGraphics
This board if the best ever....I have a customer that want to bring me 2 plywood boards painted and ready to go 4 feet by 8 feet and wants me to fill it all up with lettering.
2 Color vinyl black and red.
How much do you think I should charge per plywood?
I was thinking anywhere from $200 to $250 each pc what do you guys think.
Thanks guys
juan45215
I would charge about $150 each. If there are only a few words and one color.
Shovel brings up a good point. The type of paint is a BIG issue. I lettered a sign that my customer painted and the vinyl fell off 2 weeks later.
Si Allen
I agree with Rich!!!!!!!!!!!!!!!!!!!!!!!!
Chances are that he will use latex paint and the raised grain will look like a wire brush! Also vinyl doesn't like to stick to latex paint!
$900 each if you use his plywood!
$450 each if you use a proper sign substrate!
Tim N
I just finished a 4x8 MDO customer supplied. I specified I wanted it painted with an oilbased paint preferably rustoleum with a foam roller and sure as heck It was painted with latex paint. They didn't want to hear that he needed to get another sheet and repaint it or I could for him for $170 more and he didn't want to take the vinyl RTA so he signed a waiver stating "Absolutly no guarantee as the customer deviated from original contract specs." I had a heck of a time getting the vinyl to stay down without a heat gun. I'm curious as to how long before he comes back whining.
ChicagoGraphics
We never take any jobs from customers that wanna supply us with there own plywood, most often they get the cheapest plywood (flooring) you can buy and then paint it with laytex.
Charge your customer 300 a pc. and use the cheapest vinyl you can find lol, that will teach them a lesson
iSign
WE DON'T HAVE ENOUGH INFO... BUT "FILLING UP THE SIGN WITH LETTERING" MAKES ME THINK LOTS OF WORDS.
oops... sorry for all caps... Even if it's only 8 - 10 words... the value of a 4x8 from a sign company is easily from $350 - $550
so, he bought the wood instead of you spending up to $50 for a good sheet of primed MDO ...and he spent the 20 minutes of painting it instead of you....
so in his cheapass attempt to get around paying a sign professional for a professional sign... he has saved you $100 worth of time & material...
$300 for your work if the board is as easy to work with as yours would have been... more $ if it is not flat, or the vinyl doesn't easily stick to it.
wildside
I agree with Si Allen . . . !
NO WARRANTY WITH HIS BOARDS - PERIOD !
agreed again!!
if the customer supplies the board, it usually costs more than if we supplied the board, and we do not warranty anything once it leaves the building
try and explain to the customer that his trying to be cheap will cost him more in the long run once you have to replace his boards with the way it should have been done the first time
By the way you’re describing the situation; you’re probably going to run into some problems here. You also probably want to keep this guy as a customer and turn him into a good one. So, earn his trust. :thumb:
First, tell him what everyone here has said, that by supplying his own painted material, that he has just seriously shortened the life of his own sign by his own hands. Regardless of whatever vinyl you use, it’s at the mercy of whatever he used, so you can’t stand behind it for any reason. Tell him that in the future in order for you to do a good job for him, he needs to let you do the entire sign from substrate purchase and prepping to all the decorating of it and finishing it off.
Since the harm has been done, hopefully you can use some easy weeding font and there aren’t too many words on this thing and try to get out of this for about $300.00 each. You’ll still make a decent buck and he’ll have learned a valuable lesson.
:Oops:Here's a case where I would use ‘Avery’…… LOL only kidding…..
MobileImpact
Been there and done that, Never Again!
If he's trying to save money by supplying improper substrates, do you really want them as a customer?
I wouldn't turn it away, but it would be charged accordingly. Much More than if we did it properly.
Another scenario would be:
Cut vinyl letters for customer made sign...$500.00
Bottle of Vodka....................................$20.00
Asprin for hangover...............................$5.00
Losing a customer because you tried to save him a buck, re-doing a job, and listening to customer complain............PRICELESS
Good Luck.
Kevin
MTechGraphics
this guy owns his own construction business so he knows what paint to use and what not to use. He stated they would be painted 3 coats and ready for the vinyl work. After all your input I'm thinking about $300 a pc.
Thanks guys this forum rocks!!
Geary
"Construction guys" who paint and supply 4x8s always want 'em for about a hundred a piece...."full of copy". They generally think you're getting away with murder by only lettering them. :thumb:
~Gear
Ken
A development permit notice can have an incredible amount of text.
If that's what your talking about..$300 each. (intermediate vinyl)
Even if it's longer term (regular) signage with less text/graphics then you're looking at high performance vinyl. Cost should be close to the same. I really prefer an aluminum faced, factory baked-on paint sign substrate.
Ken
iSign
...that comment makes me wonder if you even know what paint to use. A lot of construction guys who own construction companies, make houses with construction grade plywood, and paint that plywood with house paint.
Sign guys usually use a signply with sign enamels. I wouldn't be so confident that a construction guy knows what I want... but that's just me.:rolleyes:
