Hello,What message comes on the screen if any?
Sounds like a stuck key on the panel. Wiggle all of them of remove the top piece.
Keys can be checked in Service Mode.
Power off printer at the Main Power switch in the rear.Hello,
Keys have been checked, it's OK.
There is no message, just freeze, in sleeping mode Power button stays blue, or during printing Now Processing…
I'll try this.Power off printer at the Main Power switch in the rear.
Then press and hold the panel power button for 30 seconds.
Power back on at Main Switch, then panel switch.
Same problem.Power off printer at the Main Power switch in the rear.
I'll try this tomorrow, keep in touchjust a blind guess.
are all the fans spinning (and clean?)
my first thought was fan failure> circuit board flexes> intermittent connection on system board
might not be a bad idea to power down. unplug. wait 1 minutes then reseat all the plugs on circuit boards carefully
I'm sorry, but I don't understandmy advice is general, not geared to your particular model, but, 40 years experience as a tech...
that would certainly be my guess
