Hello,What message comes on the screen if any?
Sounds like a stuck key on the panel. Wiggle all of them of remove the top piece.
Keys can be checked in Service Mode.
Power off printer at the Main Power switch in the rear.Hello,
Keys have been checked, it's OK.
There is no message, just freeze, in sleeping mode Power button stays blue, or during printing Now Processing…
I'll try this.Power off printer at the Main Power switch in the rear.
Then press and hold the panel power button for 30 seconds.
Power back on at Main Switch, then panel switch.
Same problem.Power off printer at the Main Power switch in the rear.
I'll try this tomorrow, keep in touchjust a blind guess.
are all the fans spinning (and clean?)
my first thought was fan failure> circuit board flexes> intermittent connection on system board
might not be a bad idea to power down. unplug. wait 1 minutes then reseat all the plugs on circuit boards carefully
I'm sorry, but I don't understandmy advice is general, not geared to your particular model, but, 40 years experience as a tech...
that would certainly be my guess
Hello,just a blind guess.
i tcan never hurt to clean all connectors with CONTACT CLEANER (SOMETHING WITH NO LUBRICANT OR RESIDUE!)Hello,
Unplug and plug all on main board, head, headcard...
Start 24h test without print to see
				Yeah I cleaned iti tcan never hurt to clean all connectors with CONTACT CLEANER (SOMETHING WITH NO LUBRICANT OR RESIDUE!)
suprisingly, wd 40 has a line of secondary products and i have had very good results with their contact cleaner (FOR GOT SAKES, NOT REGULAR WD40, regardless of what it says on the label)
WD-40 Specialist Electrical Contact Cleaner, 11 oz - Walmart.com
Buy WD-40 Specialist Electrical Contact Cleaner, 11 oz at Walmart.comwww.walmart.com
again, NOTHING GREASY
spray the cleaner on your finger, your finger prints should turn white, washing the oils away, no greasy residue
isopropyl 91% is good for ribbon connectors and that sort of thing
