Second try
flen2000
I agree with most of what everyone said about my first try. I am not an artist and have no training in computer graphics so I can't be offended by whatever is said. The name will stay only the design will change. Critque away.
ChiknNutz
Too many effects. The single biggest issue I see at first is that the lighting is off on the lettering. Looks like it's being lit from both Top LH with more light from bottom RH?!?!?! Not diggin' the black to yellow fade either....
Whatever program you're doing this on.... take the color away and turn it into grey scale. You'll be able to critique your own work much easier this way. I’m not saying to stop posting, but you can save yourself some time and headaches by eliminating color when starting. You’ll see what values do to a design without even asking questions. It will be totally obvious. If not…….. go get a drink and start tomorrow.
mamos
I say keep trying, keep posting your efforts and keep learning.
Design is not something you will a, learn over night and b, ever no everything about.
But posting your efforts on a forum and offering yourself up for criticism you are not only helping yourself to become a better designer but everyone else on the forum
Keep it up dude you will get there in the end
mamos
jeroen
there's too much detail and too little contrast in it
IMHO a logo should be simple and bold/strong
like suggested, start in black&white
use crisp colors
don't use too much "effects"
yesterday, there was a thread posted about 'logo inspiration'
http://www.elogodesign.com/logo-inspiration-resources/
tons of good examples in there that should get you started
keep at it!
PGSigns
I learned to start with black and white from the book Mastering Layout and it was a big help. You will find as you learn that if it looks good in black and white it will look good as you add color. Less is more is something that you will hear a lot on this site and it is true. Do a search on this site for "color wheel" and in the threads you will find some good links to color wheels to help select colors and some very good information on the use of color. Try this with what you have. Change to a solid font , no effects, drop the fade on the spears and change it to gray scale. Work with the line weights on the lettering until it looks nice and clean. Then go in and work with color combinations.
Jimmy
Jillbeans
I would lose the oval entirely, left-justify the Sign Systems part and give it a nice beefy outline to set it off. Tone down the gradient as it adds confusion.
The lines are not so bad but to me they make your words look like a changeable letter sign.
Tighten up the spacing between the words too.
"technology" might look nice spaced out in all lower case in a thinner sans-serif font, unitalicised.
Love.....Jill
Flame
I would 100% start over again? Forget special effects, and think of how everything flows together, how much negative space there is, how to fix it, how to make it look fluid and smooth (not rough and just thrown together). Then add colors and effects sparingly.
