What would you charge?
jimbug72
Got a customer wanting a simple silhouette image painted on the wall.
Attaching the artwork I came up with.
Customer is thinking appx 6 ft x 6ft. on a block wall painted white.
This will be my first attempt at painting a wall mural since high school... So I have no idea what to charge. I'm so out of practice that I figure it is going to take me way longer than it should so I don't want to charge the client for my rustiness so to speak.
Any and all input is greatly appreciated!
Well, based on your drawing there, he shouldn't have to pay anything until you get some problems worked out.
Putting that aside, once lettering, spacing and some other details are corrected, I would figure prepping wall, pouncing or grid, painting time and cleanup, I'd be right around $1,000 or so. About 9 hours from total start to finish.
jimbug72
Thanks Gino! The lettering I traced from a copy of a hand painted sign he already has and is quite fond of.
I would love to hear your opinions on improvement of the lettering as well as the other details and problems you see, if you wanted to offer them.
I was planning on using a grid rather than pounce pattern.
The copy is bad. Serifs don’t match, spacing/kerning is odd. Some letters tilt a little…. and most of all your thick/thins are bassacwards.
The numbers look very clumsy with those serifs. It makes it almost impossible to decipher at any distance.
The cattails, egret and fence look like the water is different under them. It has a slant to one side, then straight down for the other two. It’s not consistent.
Last….. having 1-2-3… there’s no tension no excitement no nothing going on to keep one’s eye moving. You just go up-down-up-down over and over. There’s no flow.
jimbug72
I agree with you on the lettering Gino. I'm not a fan, and think I will take your advice and re-letter it in a similar style and completely re-think the numbers accordingly. Hopefully he is not too attached to those particular letters.
The fence is actually a "Rice trunk gate" which actually sits at an angle like that when it is open to let the waters open like that. Honestly it wouldn't even be in an open area like that, but rather at a canal opening, but he wanted an egret and a rice gate in a simple silhouette, so that's what I came up with.
Do you think it might be better to maybe put the name AND phone number underneath the image rather than splitting it?
Thanks again for the design help, as well as the pricing input.
:notworthy:
allamericantrade
Only one color? Would you be able to cut it in vinyl and apply to the wall then slap the paint on and remove the vinyl? I don't do this much but if it be a possibility I would think a lot less than the 9 hours Gino came up with for the install.
jimbug72
I considered using paint mask to speed up the process, but we only have a 24" plotter right now so I would have to seam graphic. Still on the fence on that one... plus I kinda want to do this one "the old fashioned way"
  • You’re gonna have about an hour creating the original from which to work.
  • An hour or so packing everything up, driving there and setting up.
  • ½ hour to prep the wall.
  • About ½ an hour to grid the whole thing out
  • 45 minute top line
  • 45 minute bottom line
  • Two hours for the middle stuff
  • ½ hour to clean up
  • ½ hour for paperwork and filing.
  • 1 hour to pick up some beer.
Oops, I was off by ½ an hour.
I actually was estimating high since the OP said he’s a might rusty with this sorta thing.
alla… since you admitted you don’t know how to paint…. you shouldn’t say stooped things about something you don’t know anything about. For a complete newbie using your method on a flat substrate in your building in a controlled environment might be alright, but you try to put sections of vinyl down, this time of the year outside…. forget it.
It’s a block wall, do you know how hard that would be to stick that vinyl stuff to the wall and it be correct ?? Let alone, usable ?? Let alone not weep underneath creating far more touching up ??
I would however, jimbu, probably suggest a second color to your client. All the things reflecting in the water could be a dark grey and it would give an illusion of being a little more 3D.
Try arching the name over the scene, make the scene somewhat smaller and lessen the phone number, so it isn’t so overwhelming and bottom-heavy
allamericantrade
Just throwing out an idea stooped or not to learn from the response thats why there was a question mark. Yes I didn't know if it would help or not. thought thats what the forum was about. I am trying to improve myself as well as possibly helping being of help. I didn't look to what area of the globe he was from to see what his weather was outside.
Just looked. Mid 60,s temperature in South Carolina isn't terrible for installing vinyl.
allamericantrade
According to my math thats 8 hours including your beer hour.
No Problem........ :wink: Back here, tempers don't flare like out on the open boards. We all know we're here to help and cut through some of the bullchit sometimes. Sorry, if you were offended.
Yeah, mine too. I never said I could add big numbers, just paint big pictures. Besides, I really think the whole thing could be done in about 4 to 4-1/2 hours, but like I said, he said he's rusty, so I gave him the benefit of the doubt. :thumb:
allamericantrade
Your 100% correct when you say I don't know anything about paint and I'll admit it any day. I wasn't trying to offend you or your reply. I thought your number was fine on the job and at least he knows there is negotiation room. I do have a lot of general knowledge but no one can know it all. I will post a reply that seems stupid just to further my own knowledge and understanding. I am learning and if I can help at the same time it would be great. you are one of the few I would say is more reputable on here and I did feel attacked but all is good.
Jillbeans
OK first off, and not to sound mean, but that image is just awful.
If I have time before work tomorrow I will post a suggestion.
You can offer the guy a color or a black and white option.
You can project the sketch onto the wall (how high up? Do you need a scaffold etc?)
Draw over the projection with charcoal then paint with fitches.
Black and white would probably take me 6 hours start to finish, color maybe 8.
A guesstimate price for black and white 6'x6' would be about $950, color would be $1200.
Provided no scaffolding is involved.
I'd use Ronan paint. If just doing black you will only have about $40 in paint and turps.
Love....Jill
jimbug72
Thanks for all the input folks. I really do appreciate it... I'm going to try and sell him on some different lettering (I'll post here what I come up with) as well as some different arrangements.
The whole wetlands silhouette thing is FRIKKIN HUGE around here although I feel it has already been done to death, recently it seems to be getting more popular in this region.
Traditionally they are done by cutting out black paper and pasting it to white paper. I think in most areas it is usually just profiles of people's head/bust but folks around here just can't seem to get enough of the wetlands.
This lawer was pretty set on the silhouette style, "Carew Rice" style to be exact. (Carew was from our little community, and his work is hugely popular in the Lowcountry.) I'm personally not that big a fan of Carew's art, but to each his own...
I will rework the type over the weekend and post it up here for opinions/suggestions and see if I can sell him better lettering.
Thanks again on all the pricing ideas. You've all helped me a lot. I was thinking in the $900-$1100 range but didn't want to over charge the guy or leave a bunch of $ on the table.
SignManiac
Not sure how I missed this thread yesterday but, definitely an opportunity to upsell. What's there now is trash, even if the client likes it. Time to educate him and show him what he could have if he's really interested in investing a few bucks in his business and image.
The only way is by showing him. He has to clearly see the difference between what he has now and what he should have that will best serve him and his business.
When I think of attorney, I think professional. At least that's what his sign should project. Formal lettering style, professionally laid out, with proper color choices, contrast, and prioritized copy.
If I were selling to this client, I'd more than likely nix the idea of painting on concrete. I'd repaint the wall for sure, and then design a nice sign to fit that space. I'd take into consideration how far the wall is from their office, any architectural details on the building that might lend itself to the design of the sign, etc. etc.
This is an opportunity to sell a nice piece and create an effective advertisement for the client. I rarely go into a new situation and just do what the client "thinks he wants" without telling them "what they should do" in order to achieve a fantastic result for him and me.
Every single project I take on usually involves me thinking way outside the box. Besides, it's more fun and leads to a better portfolio...
