those are routable protocolsSorry for the delay. Bad flu/cold going around right now. I think it may be the main board. Connected directly from laptop to printer. PC 010.164.112.150 and Printer 010.164.112.250. opened VW and it connected. Hit print and it stopped after about two minutes. Shut everything down and tried again and the same thing.
you NEED to do one of the 4 sets of ip ranges that windows doesn't steer you out of your local network to the internet
set both devices to something in
192.168.1.xxx range
IE:
192.168.1.30 ip of pc
255.255.255.0 subnet
192.1681.1 gateway
192.168.1.40 ip of printer
192.168.1.1 gateway
if a single wire from pc to printer
or
2 wires with a switch (NOT A ROUTER!)
you can leave gateway blank
set ip's on both devices, power printer off, then back on
do the same for the pc
then
START>SETTINGS (THE GEAR)
NETWORK & INTERNET>ADVANCED NETWORK SETTINGS>ADVANCED SHARING SETTINGS>ENABLE NETWORK DISCOVERY & FILE AND PRINT SHARING
SET IP OF PRINTER IN SETUP on your rip
