I seem to be getting the same feeling as the others about the scale of the elements. I'm looking for the name to be larger or the shamrock smaller. The flourish of the the "y" is getting lost in the knot.
I didn't have issues with the legibility of the name, though. I just didn't know what a "Faricy" was until you explained it. Doing a little node editting on the dot of the "i" by lifting it up may help with the legibility. ...maybe some node editting on the "y" too to make the descender more pronounced, too.
Another observation: You've got quite a bit of detail in the ribbon and shamrock whereas the name, doesn't have those details. It seems to be stuck between not enough detail or not enough contrast to the detail. if that makes sense, I'd try to push it one way or the other by either adding more detail to the type --- outlines, underlines, color --- to get it to blend in. Or, adding something to the background getting it to stand off and contrast from the details like an arched box or a another ribbon, maybe.
