"Doodle All Day" Logo Design
high impact
Here is a logo I'm working on for a trucking company (finally received a deposit). It has been VERY difficult getting to this point with this customer; he has some photshop in his background and wanted to initially use a semi he found on google...I did some research and found the rightful owner of the artwork and he would not sell.
They loved Deaton's cartoon semi truck when I showed it to them. I ordered the cd's but they are not here yet. I'm posting with a pic of the semi from the website so forgive the pixels.
They are insisting on the semi with the green/yellow fade and the triangle. They would like orange worked in if possible. Here are a couple initial attempts...what do you all think? I'm open for suggestions.
SignManiac
Too many visually conflicting rhythms going on. Very busy and difficult to read. Go for legibility and clarity in your design. Less is always more.
high impact
I agree less is more...
I don't think it is quite there yet, that's why I posted it. But I also don't think it is that bad either. Part of the difficulty in legibility is the low resolution. I'm more concerned about color, balance and font selection.
Please read my above post to see what the customer is insisting on. Some of the elements I don't have a choice on...such as color.
Any positive ideas???
Jillbeans
Bottom right has potential if you straighten out the triangle.
The fade colors in the header are a bit harsh.
I would straghten the triangle and put in a reverse panel at the bottom of it to ground both it and the truck, then add the trucking part in it in a font like Impact.
I don't much care for the script as it is very hard to read.
Love....Jill
Don't use a letter fade with upper and lower case.... it tends to cut letters and words in half and create new hard to read words.
It looks more like a T-shirt painting you'd find at a carnival than someone's logo.
It's a little too busy.
ovrcafnatd
I think it's coming along there now, but too many gradients maybe and
also I think the truck could stand to be a bit larger so it has more impact
it seems to get lost in there to me
nice start
craigco
I think it's getting better also. I do think the truck kind of gets lost in all of it. So I guess it must get larger or the other graphics around it smaller. I wonder what a light outline around the name would do.
high impact
I think we are getting pretty close if not there...What do you think of the silver being chrome?
Thanks to everyone and their input. This is much better than I started with!!!
:U Rock:
Jillbeans
I would make only the triangle chrome. Chrome can be very difficult to read (and weed)
I think I would make the header slime green and leave the gradients on the truck.
It does look much better and more balanced than it did, and I like the rule lines better than the panel I'd suggested.
Not keen on the bottom line countouring the text tho, I'd make the text all caps and change the ampersand to one in the header font. Or just drop the bottom line down a bit.
Love....Jill
high impact
I did try all caps and did not like that at all. I moved the rules lines apart to give a little more breathing room and changed the ampersand. I had to "fatten" it up a little to get it to match the font...but I like it a ton - Great idea Jill!
Yes, chrome is a pain...we just did an econoline cargo van and the customer wanted chrome shadows on almost everything! It actually came out looking pretty good.
craigco
I think a little more seperation between the lettering and the truck might work well. Seems a bit crowed and busy.
