freshening up logo
Dan Antonelli
I think the black line that runs vertically next to you S in SIGNS throws it off a bit. Might be better off eliminating the white framing perhaps.
As for type, you have to marry up your need for a condensed face for SIGNS and and extended face for TO YOU. Or you could run them in the same face, and just adjust sizing to get them to fit. So then TO YOU gets bigger.
You could try shadow under the dude to be 10% grey, also. And a red panel exclamation with white k/o might look cool...
Also, if you are tweaking, might be cool to have the sign slightly rotated 10 degrees counter-clockwise.
JERHEMI
Had some time to work on this some more today...let me know what you guys think! Dan, is this what you had in mind for the shadow? Thanks
JERHEMI
The first one has the oval and the other two I was trying to base the shadow off perspective but I think I'm off a little bit...any suggestions? Thanks
JERHEMI
Hello there guys & girls! Attached is an updated concept let me know what you think!
Also, do you like the bolder "TO" on the left better or the lighter "TO" on the right? Thanks
Dan Antonelli
Sorry this took so long- few ideas based on your current brand. I kind of like bottom right with sign angled.
To me, this is a brand I'd remember. The illustration needs a little work (ie. left leg is too close to the sign, etc) but the concept is there-----
