Dan Antonelli
I think the black line that runs vertically next to you S in SIGNS throws it off a bit. Might be better off eliminating the white framing perhaps.
As for type, you have to marry up your need for a condensed face for SIGNS and and extended face for TO YOU. Or you could run them in the same face, and just adjust sizing to get them to fit. So then TO YOU gets bigger.
You could try shadow under the dude to be 10% grey, also. And a red panel exclamation with white k/o might look cool...
Also, if you are tweaking, might be cool to have the sign slightly rotated 10 degrees counter-clockwise.
