Make little shelves out of wood with L brackets and line them up at the bottom of where the sign should go. When you lift the sign up, it will hold it in place perfectly level. No second person needed.
I just use a couple drywall screws into the poles. I use them for everything. Built my shop with them. I measure down from the top of the pole 4 feet or whatever, drive the screw in, then the same on the other side, and sit the sign on them, put a screw in the top corner, then level and attach and then take the screws out when I finish, or use them to fasten the sign.
I have switched everything over to MDO... much easier to work with than the 1/8" aluminum that rips off the screws in a good Texas Wind.
Then either put a vinyl 2" cut circle over the heads, or paint them.
Paint your fasteners for that Texas quality finished look
Huh? Just use your nog to figure out where the screw goes in one of the top corners, then swing up the other side until it is level.
I used to do that until one day it was windy and a gust took ripped the sign off the post at the corner while I was leveling it. My method keeps it secure until you get some screws in it. We have strong wind here in Texas so ya gotta work around it.Huh? Just use your nog to figure out where the screw goes in one of the top corners, then swing up the other side until it is level.
That's pretty much what I've done my whole life, but now that I'm getting older and still doing these things, I'm tending to take some of these easy gimmicks and use them also the last year or two. Slinging a 4x8'x3/4" MDO board ain't all that easy anymore.![]()
YES! I always cringed when I saw those orders, because I knew it was a money loser unless there's a system in place that, basically, says "take it or leave it.""...real estate agents are the worst. They are usually arrogant, demanding, and unrealistic..."
I don't know if we are the company referred to in other posts but we are probably one of the largest real estate sign installation companies in the country ( at least in New England). We have 13 full time year-round drivers and an office staff of three covering all of CT & RI and parts of MA.
We have been asked to go into the NY area by our customers which would be very profitable but p/u trucks are not allowed on the parkways- passenger cars only.
I also have a family member that has his own company installing RE signs in PA covering Eastern PA & NJ.
We have developed a good crew over the years and can pay well for those that are willing to work.
Our employees have been here an average of 5-10 years. 4 drivers have been here 15+ years.
A couple of years ago, one of our drivers made over $80k working probably every day for a couple of months in the summer when we are the busiest.
Some areas are more profitable than others, densely populated areas are the best.
If you are starting fresh and are looking for a computer program to take, process & bill sign orders there is a program called up sign down managed by some programmers in CA. We use it for one of the areas we work in and it works, it does the basic function of taking and processing orders but it is also lacking in the area of inventory control. It does send an email and picture of the completed transaction to the customer which is nice.
Anyway, if you have a good relationship with the realtor and want to give it a shot it could add to your bottom line.
