Honest opinions
slappy
how much would you charge for a job as such?
I need to rush a price on this and they wanted me to do it this weekend but i need to order vinly and that won't be here till tuesday so thank god for that!
Using avery high performance for this vehicle.
I'm thinking $300 to $350 but not sure. The original layout didn't have all the outlines around every piece of text. I know that it's going to be a pain now. I didn't create the mock up of this, they did.
I'm also waiting for an email in the vector format to see what needs done to get it ready for cut.
I also have to drive a few minutes up the road to install it in their warehouse as we don't have a bay door tall enough for this vehicle to fit in.
HELP ME!!!! I'm so stuck!:help::help::help::help::help::help::help::help:
Mike Paul
Super Active Member
Not with all the outlines on everything. Your almost lettering it twice. $650 seems about right.
I'd Edge print the navy blue or black? on silver.
$350. isn't bad, but we'd be a little higher in our shop. Doing it on site because you can’t accommodate his vehicle is a little tricky. Sometimes, if the customer doesn’t have a place you’d have to rent one to get the job done, so his giving you a warm place makes me think you have a fair price. A tractor or moving van is a different story, but a normal size vehicle shouldn’t be done outside, so you’re at their mercy. Tell them that you’re giving them $50.00 off at the $350. price for using their facilities… they’ll just suck that part up and love ya for it. :Big Laugh
HOWEVER, DON’T USE ‘A V E R Y’ ! ! ! No matter what you’ve been told, I still read and see nightmares with that stuff. Cut your loses before you obtain any. It’s just a matter of time. Ask me how I know !!!:wink:
i'd be at roughly $400for the installation and roughly $500 for materials, file preparation, cut, weed, tape, incidental materials, etc. assuming this is just premium material nothing reflective.
Buddy
Go thru the job in your head each aspect....figuring up how many hours you'll think it will take. Don't forget to add in for talking to the customer (S & S sketch & sales time.) Write your hours down and description on paper as you go thru it in your head. This is your worksheet. Multiply those hours X an $ houry rate based on your strengths & weaknesses. My guess based on some of your posts might be around $35 - $45 per hour ? You be the judge of that. Adjust the final amount up or down based on how your feel with certain factors such as customer expectations, good customer / bad customer adjustment, your geographic location (rual area or metro area) and competition prices.
Add for materials if that is going to amount to much $$. We use Avery all the time - have for years.
Add 15% to your total for your company. (this is important....that's the money left over at the end of the year)
Shoot the customer the price. Then keep track of your hours on the job and see how you come out !! It's a good method and you'll find it fun.
My dad always told me.....you'll never "loose" money on the job.....you just might not make as much as you thought. It's been my experience I always make more money per hour than I thought I was going to just because the job usually goes faster han I estimated. That's MY gain.
Get'ya some !! :glasses:
MobileImpact
I would be about $500 using Oracal film.
I would be about $2000 using Avery.
Just Kidding. About $500 using either, but listen to the masses and avoid
the Avery.
Kevin
iSign
what???
everybodies so low???
how much of that has an outline on it?
Are we looking for the right price. or the lowest possible to get some work to go eat?
If I was busy, I would NEVER do all that for $500... no matter where I lived!
Just go back to percieved value... JUST 2 doors & a tailgate, in logotype, 2 colors... that's got to be $200 right there.
Then all that tiny text on the camper back... that's equal to more then another $150 pair of doors...
now look at the sides... you figure your about half done now. Hell, I wouldn't even install that job for less then $400 if it was already cut for me.
GoodPeopleFlags
We use Avery A9 on practically everything and haven't had any problems except for one van that was lettered with the bad batch, spring of '04. But it's not like I own stock in them or anything so use whatever makes you feel more comfortable. Just wanted to throw in the fact that speaking from a company that using almost solely Avery A9, no problems here.
iSign
Valid point K.B.
...but I think a lot of us talk smack about Avery not because we fear every roll coming out of that place... but more because they became aware of the problem AND the magnitude of the problem LONG before many shops encountered problems. They could have pulled the products from shelves before shops like us ever bought them... & before we went & spent hours selling, cutting & installing numerous jobs with material they already knew was inferior... but were too cheap to pull from the shelves...
...then when the crap blew up so completely... they only seemed to compensate the minority who worked the hardest for compensation... they could have minimized their exposure by pulling all the bad product as soon as they knew about it...and/or minimized the negative perception by their market (us) by being more professional in dealing with claims.
For the record, I never did use Avery, & thus.. never encountered any losses... but as is evident... I usually have an opinion... so there it is!
Techman
YA. Avery is getting the diss because they knew there was a problem long before every else knew about it. I had a bad roll of white that shrank on the roll at least 1/2 inch still on the log and no one would admit it shrank.
And, they denied there was a problem until it was obvious they were busted. Then, instead of following the johnson& johnson model (admit and fix) they tried to spin it that if someone had a problem,, it was an isolated happening and usually the fault of the installer.
So now people avoids avery openly admitting they are still pissed and will stay pissed.
slappy
thank you guys/gals.
I quoted them $450 and on my quote email i mentioned that $50 was deducted for use of their facility (thanks Gino for the idea) And Mike Paul, you really opened my eyes with the "lettering it twice". I knew that the outlines would suck and they were not on the first layout they sent me, but hearing you say i was lettering it twice, i was like, wait a minute hereeeeee, i was more concerned about lining up the outlines till you said that and wow, thank you. I will never look at outlines the same. lol
This is the company i was talking about yesterday. They are cheap and i have a heluva time getting paid from them. I highlighted in red on my quote sheet "this signed contract constitutes to proceed along with deposit"
also the deposit amount
also mentioned it on the email as well
thank you all
I'm still using avery. I'm not use to any other material besides that and Kapco. I'm expecting some samples from Stouse that i heard about on one of the post yesterday, and a few other venders i called. i heard about the avery thing, but just haven't tried anything else yet and really haven't had any problems.
Buddy
Hard time getting paid = lack of confidence sometimes on our part to simply stick your hand out....palm side up.
Remedy: Always....ALWAYS....get a deposit. Then you have the "I'm going to take your sign back if you don't pay" fake threat you can use. On vehicles....I hold onto the keys until they trade me a check for the keys. And let them know ahead of time the dollar amout.
When you get my age (53) you get an attitue that is good and bad. Bad for some to put up with who work with you but good when it comes to things like getting paid !!
For some odd reason....I feel like I am just as important as most all of my customers. I resist feeling like I have to beg the customer....just hoping to get the job and then hoping to get paid. Heck sometimes I think I'm actually better than they are even !! (kidding around)
Realistically.....I probably get more jobs because of that approach.
Jillbeans
Never undersetimate the value of a customer's heated roomy garage!
Gino had a great idea about the "discount".
In our area, that's a good price.
It's not a big old fancy job, just a buncha text and layers.
Make sure you bring a hair dryer and a felt squeegie...if I recall from the pic, this looks to be slightly ribbed or textured.
Love....Jill
Jillbeans
It's not really a discount...she said it's right up the street, and this way she doesn't have to letter it outside. Or pay to heat a garage!
It's a percieved discount on the part of the client, who thinks they are getting a deal...but Stephanie ended up charging $100 more than what she was going to.
Love....Jill
just imagine how much more money you could be making? it isnt rocket science....there is more money to be made than you are all asking for and you can not make more without asking for it.
