I just posted.. USE some FRIGGIN PAINT WITH SMITHS CREAM>>
SMITHS CREAM>is the glue...
Any friggin paint that matches the color you want to MERELY tint the smiths cream,, which is the glue. The color is just barely there.
Thanks, and I understand that you need to use a paint to tint the glue, and I know Smiths is the glue.. But I was trying to make sure that Smiths will cure properly while using an Acrylic Polyurethane Paint..
For example: you need to use an Alkyd paint in order for HoldFast smalts glue to cure properly, using anything else will inhibit the curing process.. so, ONE SHOT, works well with that ..
There is very little information to be found about Smith's cream, and what type of paints it is compatible with.. I was asking if anyone had an answer for a glue that works with Matthews (acrylic polyurethane) paints specifically, because that is what we use.. and what I have mixed to match the sign that is on site we are replacing ..
So, to not rephrase the question..
Wondering if anyone has a suggestion for a smalts glue that will work with Matthews Paint.. ? Looking for someone that has used matthews with a glue and had success..
I'm not familiar with the "FRIGGIN" Paint brand .. anyone?
