Good question!Is "10" running as a 32 or 64 bit program?
(if you are allowed to say under the NDA)
wayne k
guam
Hey Wayne - Flexi 10 is running still as a 32-bit program but will run on a 64 bit system.Is "10" running as a 32 or 64 bit program?
I see an that might work but what about adobe filter's & Icc Color Profiler op in Print & Cut.Hey Paxas - we've slimmed down our product line and removed the Print & Cut level. Now we have the following levels:
-Pro (advanced design, RIP & Print and cut package)
-Expert (advanced design and cut package)
-Sign (design and cut)
-Letter (basic cut package for text layout)
-Designer (Design-only, no output)
For Sign and Expert we're now offering an additional PlusPRINT option, which will add the ability to RIP & Print. We do have an upgrade path worked out for customers who currently have Flexi Print & Cut. They will receive Flexi Expert with the PlusPRINT option.
P.S. Sorry I've been a little MIA for a while. We've all got our heads buried in this release!
Steph
You always have the option to save in Flexi 5,6,7 & 8 formats.
Even if I wanted to load both or go back I can't, cause the USB key gets Burnt out when I upgrade...... Understand?
Im still using xp pro. will 10 work on that OS? and also, i have a DGI OM-70 plotter (Newstar omega), will it have that profile?![]()
So to confirm this.... your saying if I upgrade to 10 then I'll still be able to run 8.6 AND 10 on the same computer? Upgrading to 10 won't prevent me from running 8.6 anymore?The key for this upgrade won't be burned out if you already have a 500-series key for Flexi 8 or 8.6. We'll be using the same key for Flexi 10 so you will have both the Flexi 8 and the Flexi 10 password on the same key. So you could definitely have both versions running on the same computer. Hope that helps!
